Need help choosing and configuring a SSD
Solved by manikyath,
3 minutes ago, thesaltyappy said:Aight, Thanks! But why specifically Kingston?
kingston A400 series specificly, because they are pretty much the cheapest SSD per GB, and are still decent enough.
i've got two systems with the 128GB kingston A400, and given the price i paid for them, its hard to remark them in any way.
EDIT: that said, if you can squeeze it into budget, 256GB is a bit less cramped, and technically better value than the 128GB one.
