Is my hard drive done for?
Yeah drive is in really rough shape. I would try to copy off data you need/want. Use something like Unstoppable Copier by Roadkil. It works really good. Point source then destination and go. If it hits a bad sector it just skips and gives you a log afterward.
Only go after the most important data. If you have games but they can be reinstalled ignore them and only go after the save files.
Same for important documents and stuff like that. Go after what is important then replace the disk. You could also attempt a clone of the drive but only AFTER you have grabbed the most important data to you.
Keep in mind that even after a clone you could have damaged files, system may not boot right etc if it is a boot drive.
Edit:
I really should expand on why the drive cannot be saved:
When a hard drive experiences a bad sector that is an area of the platter that is no longer readable. This can be caused by many things but for whatever reason that area is no longer holding a charge. In regards to the weak sectors these are areas that hold one but have a substantially less of a charge than the surrounding sectors. They will still hold onto data but only just barely. The drive during a reallocation event will attempt to read the data from the weak sectors, put those offline then remap the data to a stock of set-aside sectors given at factory.
Unless you have the ability to force the drive to take those bad sectors and update its G-List (list of bad sectors from factory that are ignored. All drives have them due to platters not being perfect to begin with) there is no way to save the drive. Even if you could I would NEVER trust that drive for anything. This is why I don't buy refurbished drives from Seagate, WD, or any other manufacturer.
Your best bet is to try to get the data off the failing drive you need and replace it. If you have to reinstall the OS it is what it is. Same for downloading any games.
@DND Hope this clears things up.
