About installing NPM packages using terminal.
mrchow19910319
Go to solution Solved by duncannah,
yes
Is it true that if we install something globally, we do not need to care about the current folder we are in?
To put it in a more specific way, lets say that I run this command: npm install -g.
I knew it is a global installation of npm, so does it matter whether the folder I was currently in was root folder? or any other folder?
Is it that as long as we have -g at the end of it, it will always be installed into root folder?
Sorry for newbie question.
Thanks.
If it is not broken, let's fix till it is.
