digital rgb USB or PCI-E based 5V addressable RGB controller?
Solved by Dertder,
On 5/24/2020 at 11:20 AM, oscar7601 said:Hi, no unfortunately I never found any elegant solution...
On 5/29/2020 at 8:47 PM, TX_Hazzrd said:whelp, rest in peace
the Ek loop connect would be exactly what you need. It uses USB and it's own software
