port forwarding help
Flux Azreal
i port forwarded with at&t and i added the port 47984 but when i use a port checker it says its closed
reboot your router
Gaming - Ryzen 5800X3D | 64GB 3200mhz  MSI 6900 XT Mini-ITX SFF Build
Home Server (Unraid OS) - Ryzen 2700x | 48GB 3200mhz |  EVGA 1060 6GB | 6TB SSD Cache [3x2TB] 66TB HDD [11x6TB]
Also open up that port in your windows firewall on the server machine if thats what you're doing. That actually more likely the issue.
also will disabling this help? lolimage.png.64c1237761282b4f82771e1e6692d858.png
im far too lazy to port them threw firewall
