MSI afterburner and power limit
Solved by Wh0_Am_1,
24 minutes ago, Rothhaus said:
At high temps PCBs consume more power, and are power throttled to keep temps under control especially when OC'ed this allows the card to reach it's full potential, this allows for you cards to reap more performance, and reach higher clocks, and due to the fact that the card still controls how much power it uses, as long as you do not tamper with the voltage there is little to no threat of burning the card out. Now as you will achieve higher temps more regularly when this is on, this settings will put additional wear and tear upon the card, and depending on how you use it, even shorten the overall lifespan by a few years, but chances are it will be in a bin, or a dump before that occurs anyway.
