i7 8700k @ 4.7ghz low 70s to mid 80s
Go to solution Solved by Cornontheecob,
1.32v seems high for 4.7 on all cores. I would try to lower the voltage, maybe try 1.25v for an all core 4.7 OC. TBH it should be able to go lower then that just make sure that u arent experiencing too much vdroop and if so increase your llc.
also, which stress test are u using? Prime95 will put the highest demand on your system but it is not very realistic i think. try aida64 or realbench to test your setup.
HELP
My setup is 8700k @ 4.7ghz 1.320 v with max 89 on core 0 and high 80s max on other cores. I have a 280mm corsair h115i pro rgb in pull config with idle temps at high 30s to low 40s! What am I doing wrong? Did I lose the lotery?
When i was seating the cooler it came off with a bit of thermalpaste still on the cpu. Is that the reason? what should i do? help!!!!! these temps are in intel extreme tuning utility stress test.
https://linustechtips.com/topic/969486-i7-8700k-47ghz-low-70s-to-mid-80s/
The chip isnt delidded correct? seems pretty normal since i got 85C on 1.38v delidded, I've since switched back to a d15.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
Just now, WhacKuum said:
 Yes but others are getting like mid 60s why me?
mid 60s on 1.32v just doesn't happen on a 8700k that isn't delidded. you might be looking at delidded temps or inflated numbers.
1 minute ago, WhacKuum said:
Ok I will buy new thermalpaste.
just use toothpaste (not actually) but most wont make much more of a difference than others
2 minutes ago, WhacKuum said:
cpu cooler temp never goes above 55 is that normal? why such big difference in cpu temp and cooler temp?
There's immediate heat inside the cpu that can't be removed quick enough by the cooler
13 minutes ago, WhacKuum said:
HELP
Pretty normal for a non-delidded 8700k. Mine maxes out at 84C at 4.9GHz, 1.28v.
Thinking about delidding mine.
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
