Would a computer run way better if majority of its components are one brand?
Example build:
-CPU: Intel - Core i7-8700K 3.7GHz 6-Core
-CPU Cooler: EVGA - CLC 280 113.5 CFM
-Motherboard: EVGA - Z370 FTW ATX
-Memory: EVGA - SuperSC 16GB (2 x 8GB)
-Storage: Samsung - 970 Pro 1.0TB M.2
-Video Card: EVGA - GeForce GTX 1080 Ti
-Case: EVGA - DG-85 ATX Full Tower
-Power Supply: EVGA - SuperNOVA G3 750W 80+ Gold Certified Fully-Modular ATX Power Supply
https://linustechtips.com/topic/968964-same-brand-parts-desktop-rig/
they won't run any better. you get RGB sync for pairing up GPUs and motherboards from the same manufacturer but that's all.
basically that
Sometimes I have found that software between parts will work a LITTLE better but almost everything is standardized and works together regardless of brand.
