Help/Input Request: Running GPU Fans Off Of 4-pin PWN Motherboard Header
Solved by For Science!,
2 hours ago, stellarshy said:-
If you have an Asus or MSI motherboard, you can stick a 2-pin temperature probe on the back of your GPU die, stick the 2-pin header into T_SENSOR1, have the 4-pin PWM fan header run off a generic header such as CHA_1 and set the temperature source to T_SENSOR1. Whether the BIOS lets you set the PWM signal to below the minimum RPM will depending on how your fans cope with Q-fan tuning, but that would be the way to control the fan correctly by the GPU die temperature.
Honestly, quite a shabby situation with potentially an overheating GPU. Wouldn't recommend it.
