Hello People,
I am currently having a really difficult time finding a new monitor to upgrade from my BenQ GL2460HM
I have just finished upgrading my system which now has the following specs
Case - Thermaltake Core P5
Motherboard - MSI Z150A M5
Graphics Card - GeForce GTX 1080TI ROG Strix
RAM - Corsair Vengeance LPX 16 GB
Processor - Intel Core i5-6600K
Power Supply - Thermaltake Smart Pro 850W (Modular)
CPU Cooler - Cooler Master V8 GTS
SSD Boot Drive - Samsung 970 PRO 512 GB
Steam Hard Drive - WD Black 4TB
I am really looking for a monitor that has the following specs
  • 144hz
  • 1080P / 1440p (1440P is my preference)
  • G-Sync / (Don't Mind Without)
For budget I am looking for something under £550 I am open to prices higher but I would like to get a couple of this monitors
if possible.
UPDATE - This is for Gaming use
https://linustechtips.com/topic/967873-monitor-upgrade-help/
  • 144hz
  • HDR
  • G-Sync
if possible.
You can use something like pcpartpicker to have an overview of a couple of monitors with the specs you want but HDR won't be available for that price guess that will be £800+
Desktop
CPUi5-6600K MotherboardGigabyte GA-Z170-HD3P CPU Cooler: Thermalright True Spirit 120M Black/white RAM: Corsair Vengeance LPX 16 GB DDR4 2400Mhz GPU: Gigabyte 1070 HDDs: 2 x Seagate Barracuda 2TB 7200 RPM  SSDSamsung EVO 850 500GB PSU: Coolermaster 550W 80+ Gold Case: NZXT S340 (White) with a white led strip ;)
Laptops
Dell 7577
CPUi7 7700HQ RAM: 16 GB DDR4 2400Mhz GPU: GTX1060 Max-q HDD: 1TB 5400 RPM  SSDNVMe 512GB SCREEN: 4k IPS 15.6"
Macbook pro 2018
CPUi7 RAM: 16 GB DDR4 2400Mhz GPU: Radeon Pro 555X 4GB Storage256GB SCREEN: 15"
https://linustechtips.com/topic/967873-monitor-upgrade-help/#findComment-11714004
if at first you don't break it you must have followed the directions
https://linustechtips.com/topic/967873-monitor-upgrade-help/#findComment-11714005
5 minutes ago, DeclanE said:
This is primarily for gaming use.
The site I always check for reviews in my country has some positive and negative points but it's user feedback so it might be totally different for you
pro's
  • Gsync
  • 1440p
  • 144hz - 165hz overclock
  • thin bezels
  • ips coloraccuracy
  • 27"
  • no backlight bleed
  • small feet
  • twist, pivot, rotate
cons:
  • price
  • backlight bleed
  • gamer look with red feet
  • no dvi
  • ips glow
  • bad interface (OSD)
  • cheap buttons
  • big logo
  • bad speakers
All and all as IPS is always a lottery whether you have backlight bleed or ips glow this seems to be a good monitor, i always wonder why ppl that can afford this would not have a decent headset or speakers and use dvi instead of hdmi or display port xD
Desktop
Laptops
Dell 7577
Macbook pro 2018
https://linustechtips.com/topic/967873-monitor-upgrade-help/#findComment-11714078
