I have a pc with
i7 3770k at 4.5
12gb
gtx 1070 ti
and in some games I get a little bit of a cpu bottleneck and my monitor just died and it was a 1080p 75hz monitor but should I get a 1440p 75hz monitor or a 144hz 1080p and I all my games run on max setting so I can’t up the settings at all so what should I get
-My System-
Ryzen 5 1600X(@stock) | AMD Wraith Prism Cooler | 16gb Ballistix Sport Ddr4 (@2666mhz) | XFX GTS Black Edition RX 580 8gb |
Asus B450M-A Motherboard | 500gb 840 Evo Ssd | 550w evga N1 Power Supply | Vivo Micro Atx Case
-Peripherals-
Acer KG1 1920x1080p 75hz FreeSynce Monitor | Red Dragon M601 Mouse | Red Dragon K55 Keyboard |
Logitech G430 Headset | FiFine 669B Microphone | Logitech Z323 Speakers |
PcPartPicker Link
https://linustechtips.com/topic/967712-what-monitor-to-get/
Personally, I would prefer lower resolution and more FPS over higher resolution and less FPS.
I would take 1080p 144Hz over 1440p 75Hz.
https://linustechtips.com/topic/967712-what-monitor-to-get/#findComment-11712594
1440, higher refresh rate, 100hz+
I run a 1070 on 1440 ultrawide on 100hz, In majority of games im always over 100fps.
https://linustechtips.com/topic/967712-what-monitor-to-get/#findComment-11712597
