did you plug the usb cable into the mobo and did you give the hub power from the psu?
~i5-7600k @5GHz ~Be Quiet! Dark rock 3 ~MSI GTX 1070 Gaming X 8G ~Gigabyte GA-Z270-gaming K3 ~Corsair Vengeance Red led ~NZXT S340 Elite
Where are the fans plugged in?
Ok so I fixed it, I had to plug in the usb 2.0 cable form the smart
device to the motherboard.
Now all the fans are working and the rgb strip that came pre installed is also working. I attached an additional rgb strip but that one doesn’t seem to be working for some reason.
  • 4 months later...
I have the same problem. Did you find a solution?
