I'm wanting to overclock my i7 4790k and I'm a little scared as to the max voltage I can put on this chip with out killing it.
I have it running at 1.320volts at 4.7ghz and I want to try and get 4.8 or .4.9ghz if possible.
is it safe to push the voltage any higher than 1.320 on this chip?
I plan on getting the corsair h100x aio water cooler for this.
https://linustechtips.com/topic/966529-max-safe-voltage-for-i7-4790k/
Some info here, further down they say 1.30v is max for 4th gen.  You may be pushing your max, even with good cooling.
http://www.tomshardware.com/answers/id-2281662/maximum-safe-voltages-4790k.html
Onyx: AMD Ryzen 7 7800x3d / ASRock Taichi 7900xtx OC / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Sage Ryzen 7800X3D - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 CL6000CL32 32GB - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
OnePlus Ecosystem:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
1.4v should be ok, if you can cool it that is. CPU input voltage btw should be 0.4-0.5V above the core voltage
Desktop benching:
I've gone as high as 1.5v on a 4790k but not for a 24/7 overclock. If you have the cooling to handle it then anything under 1.4v is safe in my experience with Haswell.
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
If the cooler can hold out just send it. Chip needs what it needs. Especially if you want to oc like that. Id have to check some old pictures of when I ran 4.8 on mine. I don't run it like that anymore as it yields nothing in gaming for me.
lets remeber the memory controler is on the chip with haswell and anything over 1.35vcore is what saw people with dead chips after prolonged use
1.35 is the limit with haswell
-13600kf
- 4000 32gb ram
-4070ti super duper
modern CPUs' memory controller has always been in the CPU, not just Haswell. I guess you're talking about the FIVR? While that also produces considerable amount of heat, it doesnt make the CPU degrade because of voltage faster directly. It's those people not checking their temperatures close enough that causes the problem. If your CPU cooler can handle the heat, then Haswell can take 1.4V, just like the 32nm and 14nm Intel CPUs.
btw @RITIKLthe temperature I consider safe when using 1.4V is 70C full load (stress test). You might struggle with that with a 240mm rad liquid cooler
Desktop benching:
anything below 1.5 is technically okay, but 1.45 really is the spot where you won't really have to be worrying about it dying super soon. The most important thing is cooling, make sure it does not sit for hours on end at 90 degrees, as that mixed with the voltage will really kill it a lot faster. try to aim for small spikes into the 80's in the most intense situations. Although i assume 1.45 will not be achievable without going well into the 90's anyway.
i5 7600k @5.2ghz 1.39v i7 7700k @5.1ghz 1.39v / Strix z270h / 16gb Trident z RGB 3200mhz CL16 1.35v (2400mhz CL15 kit overclocked) / GTX 1070ti sli both with Arctic Accelero Xtreme iv coolers / EVGA 750w Gold PSU
Samsung cf791 3440x1440 100hz Quantum Dot
Haven't broken something with an OC yet... YET.
you've got a point there. my chips dose seem to run hot. even when I had it on a h55 aio with push+pull.
I think I will try 1.35 and nothing higher than 1.37volts.
