I’ve been looking at an rx580 deal costing 225 ish dollars, and an rx480 deal costing 200 dollars. I have an rx480 clocked at about 1266Mhz and the rx480 is clocked at the same. The rx580 is clocked at about 1466Mhz or so, I was wondering if it’s worth it to get an rx580 (I’m planning on upgrading to dual rx580s) just for now I’ve been using an rx480 and I’ve heared you can get better preformance off just the higher clock card and that the lower clock will yield worse preformance. Will it be better or worse to add the rx480 with the rx580 and wich one should I buy?
No point in doing so. Also the 480 and 580 is the same card. The latter is just factory overclocked higher.
If you want to run crossfire i recommend grabbing 2 identical cards
Noted. Thanks a lot ;)
They're the same GPU, so yes.
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
1 hour ago, Firewrath9 said:
just sell your 480 and buy a 1080 (they can be bought for ~400-450$.
https://www.tomshardware.com/news/nvidia-rtx-gpus-worth-the-money,37689.html
lol /s
CPU: Core i9 12900K || CPU COOLER : Corsair H100i Pro XT || MOBO : ASUS Prime Z690 PLUS D4 || GPU: PowerColor RX 6800XT Red Dragon || RAM: 4x8GB Corsair Vengeance (3200) || SSDs: Samsung 970 Evo 250GB (Boot), Crucial P2 1TB, Crucial MX500 1TB (x2), Samsung 850 EVO 1TB || PSU: Corsair RM850 || CASE: Fractal Design Meshify C Mini || MONITOR: Acer Predator X34A (1440p 100hz), HP 27yh (1080p 60hz) || KEYBOARD: GameSir GK300 || MOUSE: Logitech G502 Hero || AUDIO: Bose QC35 II || CASE FANS : 2x Corsair ML140, 1x BeQuiet SilentWings 3 120 ||
LAPTOP: Dell XPS 15 7590
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
