i5 7600 stuck at 800MHz clockspeeds
Go to solution Solved by Fennie,
Nevermind i updated cpu-z and it shows up the right things..
thanks for helping
Hey.. Recently i was hit with something weird on my rig..
Suddenly its stuck at around 800MHz clock, i have tried Everything.
looking in the BIOS for stuff
using throttle stop
searching forums.
and found nothing.. This is my last chance trying to fix it before taking it to a specialist/ technician.
motherboard: Asus h110m-a m.2
Cpu: i5-7600 3.50GHz
https://linustechtips.com/topic/965209-i5-7600-stuck-at-800mhz-clockspeeds/
Just now, GoldenLag said:
Is the performance any different?
Check by testing using cinabench. Or you would have pretty much noticed. Could be faulty reading
i tried running pirme95
but i didnt do anything.. ill try anyway
update the motherboard's bios
Desktop benching:
Just now, Fennie said:
its all up to date
at least CPU-Z isnt. I misread that version number below at first
Desktop benching:
Usually the result of thermal throttling. Use HWMonitor to check idle temps.
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
