Reddragon purple vs Brown Switches
Solved by manggamadu,
21 hours ago, Dragomir_ said:So in short, they are both the same feel (non-linear). But purple requires more force..?
In compassion to their own Blue switches would the brown be above or below?
I have tried Outemu blues & outemu browns, they have the same actuation force, same feel, but the blue switch is clicky (the make a click sound) while the brown is only tactile (you can feel when it hits the actuation point but it doesn't make a click sound). Outemu also has a linear switch, the red one.
While for the purple, it's the same brown but heavier.
