Macbook pro crackling noise
Go to solution Solved by jefire411,
OK, it seems like the fan really is hitting it's sounding metal. Can't do anything for that really :(
My 13" 2015 MacBook pro because it was making a weird noise when under load so I opened it up, unscrewed the fan, and it seemed fine so I screwed it back in and just like Snazzylab's iMac pro's vesa mount, the screw breaks leaving a good chunk of it inside! Now the fan isn't completely held down and it is still making that noise! I have no idea what may be causing it now. Help?
On a side note, I repasted my laptop while I was checking the fan and I noticed the heatsink is ridiculously small, Look at this thing!
https://linustechtips.com/topic/964697-macbook-pro-crackling-noise/
Just sounds like the metal unibody just expanding and contracting from the heat. Unless you can be more specific about where the sound is coming from, that is probably all that it is.
Laptop: 2019 16" MacBook Pro i7, 512GB, 5300M 4GB, 16GB DDR4 | Phone: iPhone 13 Pro Max 128GB | Wearables: Apple Watch SE | Car: 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: ASRock RX 5700 8GB | Case: Apple PowerMac G5 | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Be Quiet! Pure Power 11 600W | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Wraith Prism | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2018 Core i3 Mac mini, 128GB SSD, Intel UHD 630, 16GB DDR4 | Storage: OWC Mercury Elite Pro Quad (6TB WD Blue HDD, 12TB Seagate Barracuda, 1TB Crucial SSD, 2TB Seagate Barracuda HDD)
It's like a crackling noise, kinda sounds like a fan hitting something or the speaker issues on the 2016/17 MacBook pros. I can't pinpoint exactly were it is coming from and I don't think it's the speakers as even when off the laptop will continue to make this noise at times.
