Help pls! RGB Front Fans dont light up CoolerMaster Masterbox 5 pro RGB
So i just finished my new build, very happy and satisfied with it. However there is a slight problem; the case fans. They work as expected but doesen't light up. I have connected them to the motherboards Chassis fan 2 and to the power supply directly. After a few reboots and installing drivers it still doesent work. Any tips? MOBO: Asus ROG STRIX B360-F gaming.
PS Also i believe all the 3 fans have been adaptered together, because they are powered by only 1 to the mobo and psu respectively.
How are your fan connected, there are two cables one for fan control and one for RGB. Since your board has a single RGB header you can get splitters and connect all three fans onto the RGB header for control.
-Moved to Modding Section-
