Please helppp... sound blasterX AE-5
17 hours ago, Ap.sleezy said:
hi i plugged everything in properly and downloaded the sound blaster software but it is not recognizing my sound card. i also tried changing the PCIE express slot and still not detected. any tips?
If you are on an asus motherboard and plugged the card on pcie slot 4 or 1 then in bios you have to disable USB front panel header and change it to power to PCIE x1X4
