Headphones audio only left ear while connected thru PC but not monitor.
Hello,
The headphones I have only have audio going through the left ear when I connect them through my PC case but when i connect them through the headphone jack on my monitor it works fine, so i know that my headphones work fine.
Can someone help me to get audio through both left and right ear when plugged in through my PC case?
| CPU: AMD Ryzen 7 5800X | Motherboard: MSI MPG X570 GAMING PLUS | CPU Cooler: MSI MAG CORELIQUID 240R
 | GPU: MSI 3080 Ti VENTUS 3X 10G OC | | RAM: G.Skill Trident Z RGB 16 GB (2 x 8 GB) DDR4-3200 | PSU: MSI MPG A750GF Gold Fully-Modular | Mouse: MSI CLUTCH GM50 | Keyboard: MSI Vigor GK60 Cherry MX Red |
| Headset: MSI DS502 GAMING Headset | Case: MSI MPG SEKIRA 100R |
| Displays: AOC AGONAG241QX Gaming Monitor 24" & Acer CB282K 28.0" 2160p 60Hz HDR IPS | Wrist Rest: MSI Vigor WR01 Wrist  Rest |
Hey Ja55ie,
Have you tried looking through the audio settings to see if you may have them set for Mono audio instead of stereo?
If you have then you may have an issue with cable connection inside your PC (assuming the connector is on the front of the case!)
~~~ MY RECENTLY UPDATED RIG ~~~
CPU: AMD Ryzen 7 2700
MOBO: ASUS Prime B450M-A
GPU: ASUS RX580 Dual 8 GB
RAM: 4 x 8GB Team T-Force Vulcan 2666Mhz
Cooling: Corsair Hydro Series H150i Pro RGB
PSU: Silverstone 80+ Platinum 750W Fully Modular
Case: Cougar Panzer Dual Tempered Glass
Storage: Samsung 840 500GB 2.5" SSD
Storage: SanDisk 240GB 2.5" SSD
Storage: LiteON 240 GB 2.5" SSD
Storage: Toshiba 3TB 7200rpm 3.5" HDD
PC Part Picker list:
https://au.pcpartpicker.com/list/4bH3V6
45 minutes ago, Dufsao14 said:
Hey Ja55ie,
46 minutes ago, Zmax said:
You could have a damage PC connector, Have you tried the front connector on the PC ( phone jack )
You could get a USB Headphone adapter if you need
@Dufsao14 Hey I have made sure to set it to stereo in my Asus audio setting and verified in windows as well.
I may have a connection issue the front connection and i'll have to double check that.
@zmax that was the only connector i tried on the pc itself and i haven't tried the rear one. Yes I may need to get a USb adapter.
I was able to tweek the balance in the speaker properties so that it sounds even from both ears. So I guess it's sort of a fix at the moment.
Thanks guys
