Spec:
Cpu: i5-4590
MB- MSI Z97 Gaming 3
GPU- NVIDIA GTX 1070 Strix
Ram - 2x8 GB DDR3 CORSAIR VENGEANCE
PSU - Xilence 750w
Win 7 x64
BIOS - V2.6, 12/24/2014
Hello everyone,
Recently, in the past couple of days got 3x BSOD.. Nothing particular that i did at that point of time, but in the last weeks i upgraded some PC parts like, new Ram, case, air fans, mouse..
Only thing that i can think of is that i bought faulty ram.. ?
In the attachment there are the mini-dump files and Sysnative BSOD Dump File.
I ask for your help, to try figure this out as i didnt succeed!
Thank you in advance!
Regards,
Tucinieks
SysnativeFileCollectionApp.zip
081118-7160-01.dmp
082018-6380-01.dmp
082218-6427-01.dmp
Report from Cmd.html
https://linustechtips.com/topic/963954-recent-bcod-that-i-need-help-with/
I have a BSOD debugging tool set up in my office. I'll run your dmp files through it tomorrow AM
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
ok, on the top crash dump file, the error came from
SYMBOL_NAME:  nvlddmkm+46d9c4
The 2nd one was this:
DEFAULT_BUCKET_ID:  WIN7_DRIVER_FAULT
While in Chrome.
The last one was this:
IMAGE_NAME:  msahci.sys
Looks like you either have multiple out of date drivers, or bad RAM.
While in Chrome.
Okey, i will update Bios and all other drivers that i can, and see if anything changes! Thanks for this!
Any idea maybe how to recreate the shutdown? or somehow test the ram sticks?
Sure, scare up a copy (it's free) of Memtest86+. Run for 24 hours *minimum* and it will find out if your RAM is bad or not.
If it is, you'll know it immediately, and in which case you can stop the test as you have your answer.
http://memtest.org/
http://memtest.org/
Ok, i will try it! Thank you Sir!
Since the Bios update havent had a crash yet, but its too early to judge.
