Need help with 980TI (dying card?)
Solved by Brews,
I've actually managed to solve it. Simply changing the resolution down from 2560 x 1440 to 1920 x 1080 and then back again seems to have fixed it. Driver / windows problem?
edit:
The above text is not entirely correct. As I changed the resolution, the refresh rate was also lowered from 144hz to 60. Increasing it to 144 again made the problem arise again. It doesn't seem to be visible at 120hz either, only at 144.
