I was wondering how well a CX550M would work on a system that includes a xeon x3440 overclocked to 3.6 ghz on stock voltage and a 290x at stock. I will be trying to undervolt the 290x as far as it'll go, but some insight would be nice.
8086k Winner BABY!!
Main rig
CPU: R7 5800x3d (-25 all core CO 102 bclk)
Board: Gigabyte B550 AD UC
Cooler: Corsair H150i AIO
Ram: 32gb HP V10 RGB 3200 C14 (3733 C14) tuned subs
GPU: EVGA XC3 RTX 3080 (+120 core +950 mem 90% PL)
Case: Thermaltake H570 TG Snow Edition
PSU: Fractal ION Plus 760w Platinum
SSD: 1tb Teamgroup MP34  2tb Mushkin Pilot-E
Monitors: 32" Samsung Odyssey G7 (1440p 240hz), Some FHD Acer 24" VA
GFs System
CPU: E5 1660v3 (4.3ghz 1.2v)
Mobo: Gigabyte x99 UD3P
Cooler: Corsair H100i AIO
Ram: 32gb Crucial Ballistix 3600 C16 (3000 C14)
GPU: EVGA RTX 2060 Super
Case: Phanteks P400A Mesh
PSU: Seasonic Focus Plus Gold 650w
SSD: Kingston NV1 2tb
Monitors: 27" Viotek GFT27DB (1440p 144hz), Some 24" BENQ 1080p IPS
https://linustechtips.com/topic/963155-new-build-power-requirements/
6 minutes ago, brob said:
I suspect 550W is not going to be enough, even undervolting the r9 290X. At stock with 1 drive the system would likely have a maximum estimate above 550W.
I figure that I might be pushing the power budget, so that's why I'll be undervolting. I figure at stock settings with a healthy undervolt, the 290x won't use more than 250w then I figure that my cpu is using about 110w with rest of system consumption being 50-70w. So, I believe at worst on a stress test I'll be seeing numbers around the 400w mark, possibly 450w if my numbers are off. I tend to not trust psu calculators due to them inherently being used to sell higher end products. With these numbers, do you think the CX550M will be able to handle the sustained load?
8086k Winner BABY!!
Main rig
GFs System
You should be fine in gaming loads, just don't do any heavy rendering or stress tests. Not so much about power requirement, more about PSU quality
The CXM line seems to be pretty good according to the updated psu tier list and jonnyguru reviews, so I figure it can handle anything that it's rated for well enough. Do you think I'll be hitting power limits if I stress test?
8086k Winner BABY!!
Main rig
GFs System
Buy a Kill-A-Watt if you want to watch what your power draw from the wall is
The estimate I mentioned is simply the addition of max power draw estimates from the various manufacturers. You should be ok.
