Managed to grab 2 MSI RTX 2080 TI Gaming X Trio.
May i know if a Corsair AX1200i would be suffice?
Price is crazy in Malaysia. paid around usd3000 for it
So You Wanna Be A Playa, But Your Rig's Ain't Fly,
You Gotta Hit Us Up, To Get A Pimped Out Rig,
You've Got To Pimp My Riggggggg...  (DAMN RIGHT)
https://linustechtips.com/topic/962816-psu-for-sli-rtx-2080-ti/
Nvidia recommends a 650-watt PSU for a single car system. An AX 1200i has 8 PCIe power connectors, and each 2080 Ti requires 2 (for a total of 4).
You're fine.
CPU: Ryzen 7 5800x3D || GPU: Gigabyte Windforce RTX 4090 || Memory: 32GB Corsair 3200mhz DDR4 || Motherboard: MSI B450 Tomahawk || SSD1: 500 GB Samsung 850 EVO M.2 (OS drive) || SSD2: 500 GB Samsung 860 EVO SATA (Cache Drive via PrimoCache) || Spinning Disks: 3 x 4TB Western Digital Blue HDD (RAID 0) || Monitor: LG CX 55" OLED TV || Sound: Schiit Stack (Modi 2/Magni 3) - Sennheiser HD 598, HiFiMan HE 400i || Keyboard: Logitech G915 TKL || Mouse: Logitech G502 Lightspeed || PSU: EVGA 1300-watt G+ PSU || Case: Fractal Design Pop XL Air
https://linustechtips.com/topic/962816-psu-for-sli-rtx-2080-ti/#findComment-11667855
1 minute ago, Firewrath9 said:
ax860i
Pretty old design.
You're fine.
A 550W unit would probably be fine for single card. 850W would be fine for two cards.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/962816-psu-for-sli-rtx-2080-ti/#findComment-11667856
2 minutes ago, VegetableStu said:
wait for reviews to be sure. look at Nvidia's page to be quick
That won't be able to power 2x RTX2080tis in SLI.
Battersea Power Station closed down 30+ years ago. :D
https://linustechtips.com/topic/962816-psu-for-sli-rtx-2080-ti/#findComment-11667858
I'd be careful with that recommendation. The 2080 Ti has 2 8-pin PCIe connectors. An 850-watt PSU might be cutting it a bit close for 2 cards.
Until we see reviews with power numbers, I'd recommend a 1000-watt PSU minimum for  2080 Ti SLI.
Also, his original post asks if an AX 1200i would suffice, to which I replied "yes". (because it will)
https://linustechtips.com/topic/962816-psu-for-sli-rtx-2080-ti/#findComment-11667859
2 minutes ago, MadPistol said:
I'd be careful with that recommendation. The 2080 Ti has 2 8-pin PCIe connectors. An 850-watt PSU might be cutting it a bit close.
215W TDP. NVIDIA cards always fall below the TDP in power draw (well, most of the time), so let's say 205W. 205W + 95W CPU (i7-8700K) + 150W overhead = 410W. It'll be just fine as long as it's a quality unit.
2 minutes ago, Firewrath9 said:
Huh. Didn’t know that. It’s still platinum and tier 1 tho.
And there are still better options out there like EVGA P2 and Corsair HX tho.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/962816-psu-for-sli-rtx-2080-ti/#findComment-11667870
3 minutes ago, Firewrath9 said:
what’s the current flagship? The HX-series?
AXi, but the 1200W+ version that aren't too old. The 760/860 have kinda been replaced by HXi which has a newer design and quieter fans
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/962816-psu-for-sli-rtx-2080-ti/#findComment-11667871
I’ve had good experiances with corsair, i usually reccommemd them and as he is dropping 6k for those cards, i went with corsair’s flagship. Not sure about evga’s PSU’s I only used a NEX in a build.
see edit about the HXi-series. Nvm
https://linustechtips.com/topic/962816-psu-for-sli-rtx-2080-ti/#findComment-11667872
You do realise how much power a computer with GTX 580 SLI or R9 290X XFire uses?
About 631W (after factoring in power loss from converting AC to DC) for a system with an Extreme Edition and R9 295x2
Image result for r9 295x2 power consumption
https://linustechtips.com/topic/962816-psu-for-sli-rtx-2080-ti/#findComment-11667878
Except it's their old flagship...
Corsair makes shit PSUs too, EVGA makes great PSUs too...
Never trust the brand, trust the model...
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/962816-psu-for-sli-rtx-2080-ti/#findComment-11667880
I’m not saying all of corsair’s stuff is amazing, and evga’s stuff is bad, I like evga mobos, AIOs and Graphics Cards.
https://linustechtips.com/topic/962816-psu-for-sli-rtx-2080-ti/#findComment-11667885
I'm getting too old for this...
From Nvidia's site.
https://www.nvidia.com/en-us/geforce/graphics-cards/rtx-2080-ti/
Lets assume that he's going to overclock (as that is a worst case scenario) and Nvidia currently has graphics card power listed as 260-watts. At full tilt, that's 520-watts right there. NOW lets assume he's got the CRAZIEST consumer hardware you can buy (because he did just purchase the two most powerful Nvidia consumer graphics cards). That would be the Ryzen 2990wx, and according to Tom's hardware
https://www.tomshardware.com/reviews/amd-ryzen-threadripper-2-2990wx-2950x,5725-13.html
That's 1000-watts
All things being equal, I'd recommend a 1000-watt PSU, especially since we don't know the true power consumption of Nvidia's 2080 Ti or what sort of other specs he currently has on his system.
Do you understand my reasoning? I'd much rather over recommend and he have room to spare than under recommend and he be unhappy because some random joe on a forum said an 850-watt PSU can power my 2990wx and 2 2080 Ti's at full torture test levels... and until I get more information, either from reviews with power consumption figures, or from the OP with his actual system specs, I will be sticking with this recommendation.
Also, a Corsair AX1200i is completely and utterly fine, no matter what, which is what the original question was, anyway.
https://linustechtips.com/topic/962816-psu-for-sli-rtx-2080-ti/#findComment-11667891
Wrong, 2080ti has 250w TDP (2080 has 215w). You're looking at the wrong place. When overclocked with power limit raised (let's assume 20% for 10 series reference cards, since we dont get 3rd party reviews of 20 series cards yet), you get 300w power limit.
Also, 8700k when overclocked to 5GHz+ (which I totally expect someone buying 2 2080ti will do) will draw ~200w. Since 8700k draws exactly 50% more power than 7700k with 50% more cores, I can suspect the 9900k at 5GHz to draw ~270w, maybe higher if its frequency goes further up.
Apply your 'equation' again, that's 650w with 8700k, 720w with 9900k with a single 2080ti, everything overclocked. Two 2080ti? 950w with 8700k, 1020w with 9900k. Oh dear.
Desktop benching:
https://linustechtips.com/topic/962816-psu-for-sli-rtx-2080-ti/#findComment-11667914
Just now, Jurrunio said:
Wrong, 2080ti has 250w TDP (2080 has 215w). You're looking at the wrong place. When overclocked with power limit raised (20% for 10 series reference cards), you get 300w power limit.
Go with a Ryzen 2990wx and you're WAAAAAYYYYYYYYYYY over 1000-watts. lol
https://linustechtips.com/topic/962816-psu-for-sli-rtx-2080-ti/#findComment-11667918
Ordered one with zenith extreme and its on its way towards me. Was hoping to get meg x399 creation but no availability yet in Malaysia.
https://linustechtips.com/topic/962816-psu-for-sli-rtx-2080-ti/#findComment-11667939
AX1200i would be a good choice for 2990WX + 2x RTX2080tis.
https://linustechtips.com/topic/962816-psu-for-sli-rtx-2080-ti/#findComment-11667947
I wont be using my 2990WX with 2080ti's.. i would go for quadro rtx instead
https://linustechtips.com/topic/962816-psu-for-sli-rtx-2080-ti/#findComment-11667972
From Nvidia's site.
That's 1000-watts
a 7980XE on lm2 can draw almost 2k watts...
a 1080 ti can reach 1200 watts on ln2...
4 1600 Watt PSUs shoukd be fine.
good luck overclocking!
https://linustechtips.com/topic/962816-psu-for-sli-rtx-2080-ti/#findComment-11668010
Okay i think i'll go for 1600 for futureproofing. Thanks.
https://linustechtips.com/topic/962816-psu-for-sli-rtx-2080-ti/#findComment-11668110
1 hour ago, mikedrewsmy said:
zenith extreme
ohhh dear. Asus calls it 'extreme', but they will send you a 40mm fan to put on it as an aferthought because apparently it's not enough for the 32 core.
Desktop benching:
https://linustechtips.com/topic/962816-psu-for-sli-rtx-2080-ti/#findComment-11668120
