I have Ryzen 1700, Asus B350 plus coolermaster 212 led, TX550W goldPSU on test bench, no dust
I used to have stable OC at 3.8ghz / 1.3v but recent months it wasnt stable anymore. (Temps at 85C under load)
I cant even get stable for 3.9ghz/1.45v temps go up to 95C
Will water cooling Help? but I see people OC to 3.9-4.0ghz on air........
is there anything to do with B350 power phase? (similar to X470 have better power phase to B450?)
https://linustechtips.com/topic/962813-need-help-oc-ryzen-1700-on-asus-b350-plus/
If you want a really good cooler for the 1700 look at the D15 from Noctua.
Try remounting the cooler first though.
CPU: R5 3600 || GPU: RTX 3070|| Memory: 32GB @ 3200 || Cooler: Scythe Big Shuriken || PSU: 650W EVGA GM || Case: NR200P
Mabye look at cryorig h5 ultimate or a evga clc 240 as it is litterally a h100i. but with a different desing
