Hello Hello!!
At the moment my spec are as follows:
Case - Deepcool Tesseract BF USB 3.0 - black
Motherboard - Asus B150 PRO GAMING/AURA Intel B150 SK1151
RAM - Two 8GB (16GB) Kingston DDR4 HyperX FURY Black 2133MHz
Power supply - Corsair CX- 600W 12 cm Builder Series 80Plus
Hard drive - Seagate 1 TB Solid State Hybrid 3.5 SATAIII 64MB (6GB/s)
GPU - Asus R9 STRIX Gaming DirectCU III OC 8GB GDDR5
CPU - Intel Core i7 6700 3.4GHz 8MB BOX
Cooler - Noctua NH- U14S
OS - Windows 10
I was thinking on a Fractal design meshify C tempered glass, but i don't know if my system can fit in. Are there better option overall? I can't seem to get a good conclusion on what case to buy with my research.
https://linustechtips.com/topic/962669-advice-on-a-better-case-to-get/
3 minutes ago, Bed said:
Hello Hello!!
Your system will fit. If you need help I recommend using PcPartPicker as a baseline to help filter cases for the GPU cooler and CPU coolers, but otherwise, the Meshify C is a good case
That will definitely fit in a meshify c
CPU: R5 3600 || GPU: RTX 3070|| Memory: 32GB @ 3200 || Cooler: Scythe Big Shuriken || PSU: 650W EVGA GM || Case: NR200P
Even if i intend to upgrade to a GTX 1080? sorry i forgot to mention that.
Absolutely, even a 2080ti (though I would suggest you get an extra case fan or 2)
