Just now, GeneticParadox said:
maintenance?
nothing special just clean the fan/radiator on yearly bases and change your thermal paste every 2 years or so, also be careful about pump noise they could be symptoms of something not going right (some air entered into the cooler) anyway it comes with a 5-year warranty so you would be fine
ok thank you. https://pcpartpicker.com/user/GeneticParadox/saved/8yqmqs this is what ive come up with gonna replace fans with these https://pcpartpicker.com/product/jWtWGX/be-quiet-bl070-733-cfm-120mm-fan-bl070 what you think?
it will be fine
maybe wait to get the cooler try it and then decide if you want to change the fans 40 db is not that much since a lot of the noise will be blocked by the case
so your saying hold off on fans until i try cooler with stock?
Those are not static pressure fans, get noctua’s or corsair sp120.
the one on the cooler have a
  • Static Pressure: 4.20 mmAq (MAX)
while this corsair branded as static pressure fan https://www.corsair.com/it/it/LED-Color/AIR-SERIES-LED-CONFIG/p/CO-9050020-WW  has a Static Pressure 1.46 mmH20
so the evga one has a greater static pressure or not @Firewrath9
The evga on is louder so it all depends on you. The static pressure kf the evga ones is slightly higher.
hmmmm im looking for decent priced fans that are static pressure fans but are also quiet so which are best choice?
