Will a GTX1070 boot with a single 6-pin?
Short answer is no, unfortunately. One of the pins on a 6-pin connector is for ground sense, and two of the pins on an 8-pin connector are ground sense. If all sense lines aren't detected then the card won't POST.
Your PSU is theoretically capable of powering both cards so long as your load is low, but it's a dangerous situation to be in - if load spikes across both cards it could trigger OCP. That's unlikely however. Only being designed with one 6-pin connector means it may not be built internally for that amount of potential current to slow over the connector/cable. Be careful.
Does your motherboard have integrated DisplayPort? The built-in Intel GPU can power a 3440x1440 panel at 60Hz no problem. Actually, there's no reason your 750Ti can't either, you just have to make sure you don't use HDMI.
