Help discover double monitors where one can be worse than the other
Hey!
I recently finished building my pc and getting all the peripherals but not the monitor. At this point i have a new PC that i can only hook up to my TV, but that's not fun.
What i'm searching for are 2 monitors - Single for gaming and the both for work related stuff.
How i would like things to work:
*both monitors should be 1080 since that what people say about 1060 6gb
*one of the monitors has to be 144hz
*Both Monitors have to be the same size (what size doesn't really matter)
*They have to look somewhat the same
*My budget is kinda 350$ but i can go higher if necessary
I want one good monitor and the second doesn't have to be that good since its for word, powerpoint, programming and such, So i was wondering do monitors that look the same exist but are differing cost and quality.
Would love to hear your suggestions, thank you in advance.
You could get a 1440 monitor and just run games at 1080... but then again I also play with 3 monitors on my 2gb 960...
I have the Acer GN246HL which is 144hz, but also a TN panel. But at your price your not getting a high Hz IPS so...
I also have Acer R240HY which is a 60hz IPS.
Roughly the same size. One is 24, the other is 23.8. I don't know about the high hertz, but the IPS panel does have a 27. I'd recommend at that res to go for 1440 though. 1080 at that size starts to get choppy.
#Muricaparrotgang
