Hey I was given a Laptop, and now i dont understand the graphic card in here when i hook it up to the TV via HDMI the screen on the TV is small and says to make my resolution to 1920 x 1080 but my display only goes to 1366 x 768, and also the CPU fan kicks on when u turn the laptop on and then goes off after 5-10 seconds and off never back on.  The temp stays 50-56C and the TJmax is 105C.  Please help.
This Laptop here is the specs:
Your Intel® software is up to date.
Computer
  • System ManufacturerAcer
  • System ModelE1-510P
  • System TypeMobile
  • Motherboard ManufacturerAcer
  • Motherboard ProductE1-510P
  • BIOS VersionV2.05
  • SMBIOS Version2.7
  • Secure BootOff
Operating System
  • Version1709
  • OS Build10.0.16299
  • Build Branchrs3_release_svc_escrow
  • LocaleEnglish (United States)
  • Windows DirectoryC:\WINDOWS
  • System DirectoryC:\WINDOWS\system32
  • .NET Framework Versions2.0.50727.4927, 3.0.30729.4926, 3.5.30729.4926, 4.0.0.0, 4.7.02556
  • Default Internet BrowserInternet Explorer 11.611.16299.0
  • Installed Internet BrowsersGoogle Chrome, Internet Explorer 11.611.16299.0
Processor
  • ManufacturerGenuineIntel
  • DescriptionIntel64 Family 6 Model 55 Stepping 3
  • Architecturex64
  • # of Cores4
  • # of Threads1
  • Current Clock Speed1863 MHz
  • Current Voltage8.
  • Level 2 Cache1024 Kb
  • Level 3 Cache0 Kb
  • Processor IdBFEBFBFF00030673
  • Revision14083
  • AvailabilityRunning at full power
  • Search support for 'Intel® Celeron® N2920 '
Graphics
A customized computer manufacturer driver is installed on your computer. The Intel Driver & Support Assistant is not able to update the driver. Installing a generic Intel driver instead of the customized computer manufacturer driver may cause technical issues. Contact your computer manufacturer for the latest driver for your computer.
  • Adapter CompatibilityIntel Corporation
  • Video ProcessorIntel® HD Graphics
  • Resolution1366 x 768
  • Bits Per Pixel32
  • Number of Colors4294967296
  • Refresh Rate - Current60 Hz
  • Refresh Rate - Maximum60 Hz
  • Refresh Rate - Minimum60 Hz
  • Driver ProviderIntel Corporation
  • Driver Version10.18.10.4276
  • Driver Date8/17/2015
  • Adapter DAC TypeInternal
  • Adapter RAM2.06 GB
  • StatusThis device is working properly.
  • LocationPCI bus 0, device 2, function 0
  • Device IdPCI\VEN_8086&DEV_0F31&SUBSYS_08451025&REV_0C\3&11583659&0&10
  • Search support for 'Intel® HD Graphics'
Audio
  • Driver ProviderRealtek Semiconductor Corp.
  • Driver Version6.0.1.7535
  • Driver Date6/16/2015
  • Device IdHDAUDIO\FUNC_01&VEN_10EC&DEV_0282&SUBSYS_10250845&REV_1000\4&1C81C5AA&0&0001
  • Driver ProviderIntel® Corporation
  • Driver Version6.16.0.3200
  • Driver Date6/22/2017
  • Device IdHDAUDIO\FUNC_01&VEN_8086&DEV_2882&SUBSYS_80860101&REV_1000\4&1C81C5AA&0&0201
  • Search support for 'Intel® Display Audio'
Networking and I/O
  • ManufacturerRealtek
  • InstalledTrue
  • MAC Address20:1A:06:D4:9F:91
  • Service Namert640x64
  • Driver Version10.28.615.2018
  • Driver Date6/15/2018
  • Device IdPCI\VEN_10EC&DEV_8168&SUBSYS_08451025&REV_0A\4&39B49D61&0&02E0
  • Revision0A
Memory
  • Physical Memory - Total8 GB
  • Physical Memory - Available5.08 GB
  • Virtual Memory - Total9.81 GB
  • Virtual Memory - Available6.83 GB
  • Page FileC:\pagefile.sys
  • Page File Space1.88 GB
Storage
  • Capacity465.76 GB
  • Firmware Version01.01A01
  • Serial NumberWD-WX71AB336439
  • Partitions4
  • Driver ProviderMicrosoft
  • Driver Version10.0.16299.371
  • Driver Date6/21/2006
  • Device IdSCSI\DISK&VEN_WDC&PROD_WD5000LPVX-22V0T\4&343E2C1E&0&000000
My PC:
CPU: AMD Ryzen 5 2600X Processor (4.4Ghz), MOBO: GIGABYTE X470 AORUS Gaming 7 WiFi (AMD Ryzen AM4/ X470/ Intel Wave 2 WiFi/M.2), RAM: Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 3000MHz C15, GPU: Gigabyte nVidia GeForce GTX 1080 Windforce OC GV-N1080WF3OC-8GD Graphics Cards, STORAGE: 120GB CRUCIAL SSD, 1TB WD BLUE, COOLER: Cooler Master 212 EVO RGB Black Edition, FANS: 4 x MasterFan MF120R RGB (2 Front, 1 Back, 1 Top), 1 x Noctua NF-P12 Redux 1700 RPM(Back off Cooler), PC CASE: Cooler Master MB500 case, PSU: EVGA 750 BQ.
My Kids PC:
CPU: AMD Phenom II x4 955 (95watt @3.5Ghz @1.40V), MOBO: ASUS M2A-VM, RAM: Kingston 8GB (4x2GB) DDR2 800MHz, GPU: nVidia GT 710 2GB DDR3 (OC’ed Clock to 1300Mhz and Memory to 950Mhz), STORAGE: 250GB HDD, 500GB HDD, COOLER:  Cooler Master 212 EVO, PC CASE: Cooler Master Q300L , FANS: 3 x upHere RED LED Fans (2 Front, 1 Back), PSU: Generic 300 Watt PSU.
Console:  PS4 - vjizzle2384
https://linustechtips.com/topic/961917-help-with-laptop-gpu-and-fan/
