My screen will randomly go blank when using my computer.
Sometimes randomly when I am using my PC the screen will go black and all audio cuts out, the power button doesn't work and I am forced to switch off my PSU. Please help.
Main And Only Build : CPU : Ryzen 5 1600x (OC to 4.2GHz), Cooler : Thermaltake Floe Riing RGB 240 TT Premium Edition, Motherboard : Asus ROG Strix B450-F Gaming, RAM : Trident Z RGB 16GB (2*8) 3000Mhz DDR4, GPU : Gigabyte Gaming GTX 1070 TI, PSU : EVGA G3 650W 80+ Gold Certified, Storage : 250GB Samsung 860 Evo + 256GB SU800 + 2TB Seagate HDD.
is this a new development? it almost sound like your psu can you replace with a spare for testing?
PSU Tier Ranking List
Ryzen 5 1600x|ASROCK                      |16GB DDR4 3400Mhz Corsair Vengence   | (partial build in progress)
FX-8350 AM3+| ASUS M5A990FX V1 | 32GB DDR3 2400Mhz Corsair Vengeance | Samsung EVO 850 PRO | Win 7 64 Pro | EVGA 750W G PSU | EVGA 750 ti 6GB | Corsair H100i v1
FX-8120 AM3+| ASUS M5A990FX V2 | 16GB DDR3 2400Mhz Corsair Vengeance | Samsung EVO 850 PRO | Win 7 64 Pro | EVGA 750W G PSU | EVGA 750 ti 6GB | Corsair H80i v1
I5-2500K LGA  | ACER MOBO??         | 16GB DDR3 2400Mhz Corsair Vengeance | Samsung EVO 860 PRO | Win 10 64 Pro | EVGA 750W G PSU | EVGA 970 SC 4GB | Corsair H80i v1
No this is the first computer I have built and I don't have a spare PSU, I have reinstalled the drivers and it seems to have stopped for now, but I will update if it persists.
ok if it does it again run DDU to remove all video drivers and reinstall them.
If that doesn't work than go get a cheap 550 watt and put it in and see if that works. if it doesn't return the 550W
1 hour ago, Meritorius said:
I had this now with 2 pcs and in both it was the gpu bc they were dying. How old is your GPU?
1 hour ago, STRESSMASTER said:
  Reveal hidden contents
1. My GPU is very new I built my pc at the beginning of this year.
2. Ok thanks for the advice.
  • 2 weeks later...
Ok so I know its been a while but I bought a EVGA 650W G3 PSU 80+ Gold Certified and its still happening, I have tried DDU and no luck, it seems to happen the most when playing Fortnite and not any other games.
This problem has been happening for over 2 weeks now and I really need some help on trouble shooting. My screen will go blank mostly when I am playing fortnite, but then when I stress test individual components, CPU with Aida64, GPU with FurMark, and RAM with MemTest64, nothing happens and I get no errors, I have tried 1 RAM stick at a time and I have even gone as far as getting a higher wattage psu, from 500W to 650W. My full list of specs is this
  • CPU
    Ryzen 5 1600x  At Stock
  • Motherboard
    Asus B-350-F Gaming
  • RAM
    2*8 16GB DDR4 Trident Z RGB  At Stock
  • GPU
    Asus Dual GTX 1060 6GB At Stock
  • Case
    Phanteks Eclipse P400 Red/Black
  • Storage
    2 TB Seagate HDD + 250GB Samsung 850 Evo + 250GB ADATA SU800
  • PSU
    EVGA 650W 80+ Gold G3 PSU
  • Display(s)
    1 Asus 1080p 60Hz Monitor OC to 74Hz
  • Cooling
    Thermaltake Floe Riing RGB 240mm Radiator
  • Keyboard
    G.Skill Ripjaws KM570 RGB Cherry MX Red Switch
  • Mouse
    Corsair M65 PRO RGB
  • Sound
    Logitech Z313 Tweeter+Subwoofer
  • Operating System
    Windows 10 Home
    I dont know if this could do anything but I also have some custom cables from Antec. Here's the link to where I bought them. https://www.amazon.com/Antec-Sleeved-Cable-Extension-Extra-Sleeved/dp/B07C6CSYF8/ref=sr_1_3?ie=UTF8&qid=1535912408&sr=8-3&keywords=antec+sleeved+cable
    My temps while Gaming are in the high 60C to low 70C On my GPU and the temps on my CPU never go above 50C
Try resting the refresh rate of your monitor
Please quote or tag me @Void Master,so i can see your reply.
Everyone was a noob at the beginning, don't be discouraged by toxic trolls even if u lose 15 times in a row. Keep training and pushing yourself further and further, so u can show those sorry lots how it's done !
Be a supportive player, and make sure to reflect a good image of the game community you are a part of.
Don't kick a player unless they willingly want to ruin your experience.
We are the gamer community, we should take care of each other !
I forgot to say in the first part but I have tried that but Ill keep it at 60Hz instead of 74Hz
