Wifi add in card??
Recneps01
Looking for a decent wifi add in card for a relatively inexpensive cost.  Max $40.00 USD.  Looking for some suggestions as well as any user experiences.
The PC that it will be going into does not have any USB 3 or higher.
Thanks,
J
It doesn't have to be but it is preferred because of limit on usb ports.  I just made on edit says "The PC that it will be going into does not have any USB 3 or higher." not sure if that will be an issue?
Is this a desktop PC with spare PCIe ports you can use, or is it a laptop? Asking because getting a decent PCIe wifi card will perform better than most USB based WiFi adapters, so if this is for a desktop PC I'd recommend getting a TP-Link PCIe wifi adapter from Amazon. Something like the T6E is around $40 USD and handles both 2.4G and 5G wifi decently, even when connecting to a modern Wireless AC based router.
https://www.amazon.com/TP-Link-Archer-T6E-Wireless-Technology/dp/B016K0896K/
Desktop: KiRaShi-Intel-2022 (i5-12600K, RTX2060) Mobile: OnePlus 5T | Koodo - 75GB Data + Data Rollover for $45/month
Laptop: Dell XPS 15 9560 (the real 15" MacBook Pro that Apple didn't make) Tablet: iPad Mini 5 | Lenovo IdeaPad Duet 10.1
Camera: Canon M6 Mark II | Canon Rebel T1i (500D) | Canon SX280 | Panasonic TS20D Music: Spotify Premium (CIRCA '08)
Yes its for a desktop so i think this will work nicely.
Thanks!
