Hi,
I am looking for a micro atx case, something like Fractal Design Focus G mini would work (https://uk.pcpartpicker.com/product/vPp323/fractal-design-focus-g-mini-black-microatx-mini-tower-case-fd-ca-focus-mini-bk-w),
however I would like it to have a tempered glass side panel.
I live in uk, budget around 60GBP/80USD.
If you have some ideas, give them all :D
2 minutes ago, Altruist said:
i have the fractal design define mini c, which is a micro atx case
My best idea as well.
Just keep in mind any almost all modern, full size ATX cases can be customized (move a few risers) to fit M-ATX boards.
Main rig: i7 8086K // EVGA Z370 Micro // 16GB Gskill TridentZ 3200Mhz CL14 // Sapphire Pulse RX 7800XT// a variety of noctua cooling // Corsair RM750x v2 //  Fractal Meshify C
Secondary rig: R5 3600 // MSI B450i Gaming Plus // 16GB Gskill FlareX 3200CL14 // MSI GTX 1080ti Gaming X // Cooler Master V650 // Fractal Meshify C
Audio setup: Audient iD4 // Adam A7X // Sennheiser HD 650 // Sennheiser HD 25-II // Audio Technica M50x // Sennheiser Momentum 4
1 minute ago, RacA said:
@chckovsky
Probably any fullsize case would work however I just want a small system for now.
Yeah, ok that makes sense! BUT, then the Meshify C Mini is not suitable, it's only a bit lower in height than the full Meshify C.
1 hour ago, RacA said:
@chckovsky
My purple build in my signature used the Define Mini C, it's definitely recommendable. There aernt too many other mATX cases on the market with TG right now. Possibly the NZXT H400 depending if you feel like spending a bit more (not the H400i)
