Small Business Netwroking System Help
Solved by Electronics Wizardy,
37 minutes ago, AJ_J said:Do you have any knowledge on setting up a VPN server on 2016 wihout a domain? I also mistyped, the server is running Standard, not Essentials.
Thanks!
boom easy vpn solution. http://techgenix.com/configure-vpn-windows-server-2012-r2/
Really DO A DOMAIN. Makes everything better. Permissions are much nicer, access logging, updataes, everything. It might seem like a pain now, but its much better than the downtime.
