[SOLVED] I have two 980Ti graphics cards. How do I only use the second card, and disable the first card, without taking them out?
Fitting the PCI screws was an utter pain. Wonky almost every time.
How can I disable my first GPU, so games only make use of the second? I've tried SLI Force alternate rendering, and disabling SLI as well as plugging my monitor into the second GPU. Any ideas?
I would have thought this would be easy, with software. Can't find anything on Google.
I've also tried removing the power cables out of the first GPU. The PC doesn't post.
i7 5820K @ 4.1GHz • Zotac GTX 980Ti 2-way SLI • Full PC Specs
turn off sli
then turn off computer , plug monitor into second gpu , then turn the computer back on
In any case , the monitor must be plugged into the gpu that you want to use alone
2 minutes ago, Derrk said:
Why do you want to disable the first card?
Does it matter?
11 minutes ago, sjain said:
Does it matter?
kinda,
they are identical gpu's so there no reason to not use the primary gpu as your primary output
unless you are purposely trying to not tell us what the actual issue is and are instead trying to solve it by using the second gpu
32 minutes ago, emosun said:
kinda,
40 minutes ago, Derrk said:
Guess not. I'm just confused as to why.
If you're going to disable SLI, why not use the first card?
I'm not disabling it permanently, I am testing to see if my thermal paste reapplication has improved temps. SLI interferes with that
use gpu-z , it displays both gpu temps separately even if sli is activated or not. you can watch/log the temps of either gpu
its solved, after three reboots. just plug monitor into second gpu.
but another issue cropped up
