I am building my first Pc with a maximum budget of $1000. Here is what I was thinking:
PCPartPicker part list: https://pcpartpicker.com/list/Twryq4
Price breakdown by merchant: https://pcpartpicker.com/list/Twryq4/by_merchant/
CPU: AMD - Ryzen 5 2600 3.4GHz 6-Core Processor  ($165.99 @ Amazon)
Motherboard: Gigabyte - B450M DS3H Micro ATX AM4 Motherboard  ($69.99 @ SuperBiiz)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  ($159.99 @ Amazon)
Storage: Kingston - A1000 480GB M.2-2280 Solid State Drive  ($112.31 @ Newegg Marketplace)
Video Card: Asus - Radeon RX 580 8GB DUAL Video Card  ($239.89 @ OutletPC)
Case: Cooler Master - MasterBox 5 (White) ATX Mid Tower Case  ($55.98 @ Newegg)
Power Supply: EVGA - BQ 650W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($49.89 @ OutletPC)
Operating System: Microsoft - Windows 10 Home OEM 64-bit  ($94.89 @ OutletPC)
Total: $948.93
Generated by PCPartPicker 2018-08-09 08:29 EDT-0400
I am doing gaming, lighter video editing, learning to code, and school work. For my monitor, I just have an HP 22cwa which only goes up to 1080p 60fps with low possibly upgrading in the future so a lighter graphics card doesn't bother me. The cheaper I can make it the better.
Thank You
https://linustechtips.com/topic/958119-do-these-parts-make-sense-first-time-builder/
Drop the HDD if you've got one already that you can use. Swapped the SSD for something of better quality for a bit less money and slightly higher capacity, also did the same with the PSU.
Storage: Crucial - MX500 500GB M.2-2280 Solid State Drive  ($99.99 @ Adorama)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($57.99 @ Amazon)
Power Supply: Corsair - TXM Gold 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($54.98 @ Newegg)
Total: $999.69
Generated by PCPartPicker 2018-08-09 08:46 EDT-0400
Current Network Layout:
Current Build Log/PC:
Prior Build Log/PC:
Yah but that one is a sata m.2 I would go with an $80 sata or the cheap nvme drive I chose
Motherboard: ASRock - AB350 Pro4 ATX AM4 Motherboard  ($59.89 @ OutletPC)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  ($149.99 @ Newegg)
Storage: ADATA - XPG SX6000 256GB M.2-2280 Solid State Drive  ($59.99 @ Amazon)
Video Card: EVGA - GeForce GTX 1070 8GB SC GAMING ACX 3.0 Black Edition Video Card  ($399.99 @ Amazon)
Case: Cougar - MX330 ATX Mid Tower Case  ($39.99 @ B&H)
Power Supply: Corsair - CXM (2015) 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($26.99 @ Newegg)
Total: $997.72
Generated by PCPartPicker 2018-08-09 08:59 EDT-0400
The original drive you picked out is a SATA M.2 as well.
Unless you're doing high intensity workloads the difference between an NVMe and SATA M.2 drive is minimal at best.
Prior Build Log/PC:
Is there a good SATA SSD you would suggest? The m.2 was only because I thought it would be faster.
Either buy a cheap Windows Key at SCDKey.com or steal it.  Use that money to get a nice capacity 860 EVO at 500GB or 2-4TB storage HDD.
If you're going to stay at 1080p 60 for a while, stay with the 580 and save the money.
Onyx: AMD Ryzen 7 7800x3d / ASRock Taichi 7900xtx OC / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Sage Ryzen 7800X3D - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 CL6000CL32 32GB - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
OnePlus Ecosystem:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
500gb ssd and 1tb in the age of streaming and cloud storage is enough for most of the people
Just saw he has the external drive, and even at 5400rpm should be fine for Plex or anything else.  I personally like having my Steam library and games on an SSD tho, so 500GB SSD is mandatory, it's the best bang/buck I've had in years.
For the other builds, just note he said he wants cheaper is better.  So save the lad some money, don't have to push out the $1000 budget all the way.
OnePlus Ecosystem:
Other Tech:
Just now, DustierDolphin said:
How about the 4tb external hard drive I said I  have in an earlier post? Would that work?
Just saying I would rather keep the price down rather than going as High as I can on the PC unless it brings good returns.
Is the Samsung sata SSD really necessary? I would rather get a cheaper one from SanDisk.
it'll work just fine. the samsung SSD isn't required, you can get any brand if you want. an MX500/SX6000 are cheaper choices that perform similar.
If you are not obssesed with keeping all your games installed then 240gb and 1tb hdd is enough, I have 120gb for my C drive - system and apps, 120gb ssd for games - pubg and cs go, and 1tb for photos, heavy games - fall out 4, gta v in future
Yeah, this. I just typed 860 EVO and meant to add "or similar".   Even the cheapest 500GB SSD is a huge improvement over a platter drive.
OnePlus Ecosystem:
Other Tech:
Yah a year ago I upgraded my parent's computer from a hard drive that seemed to have problems to a Samsung 860 Evo 500gb and it saw massive improvement.
I think I would rather just get the 500gb SSD now and if I need more storage I will either get a hard drive or use the external one.
Total: $997.72
So I looked a bit more at this and have some questions:
For the motherboard: For that board wouldn't I have to update the BIOS? I would rather pay the extra.
For the case: Do you think the $20 dollars off is a valuable tradeoff from looks?
For the graphics card: Is a 1070 really worth it if all I am doing is 1080p gaming?
For the Power supply: Would it be too low?
Also is it worth it getting Windows from a 3rd party seller for cheaper?
Just saying I am not against these changes (except for the SSD which I want 500gb) because they make it cheaper for more performance just I have some worries.
Case - totally subjective, get any case you like to look at for a price you deem acceptable
Graphics - 1070 is too much for 1080p/60, get a RX580 or 1060 6GB card
PSU - 450W is plenty for that build
Windows - I've gotten 2 Windows Pro keys from SCDkey.com for less than $15 each, no issue.
OnePlus Ecosystem:
Other Tech:
newer boards will have the BIOS already updated from the factory, if not you can always just order a bootkit from AMD, it doesn't take very long.
i'd rather spend the money on a better GPU, but up to you.
not for 1080p 60hz, but if you plan on upgrading the monitor soon then it'll be worth it.
450w is more than enough for anything except a vega 64.
yes.
Thank you guys (Or gals I dunno)  so much for all the help. One last question, I may need Wifi but I am not sure yet. Should I go with a higher end motherboard with Wifi and Bluetooth or just a wifi card (cheaper)
