Hi All,
  I'm sure this sounds like a noobie question but here I go :
I have a list of 4000+ individual attendees from 100+ companies. I'd like to crate a chart that adds up all my attendees by company
(ex : Company 1 = 43 / Company 2 = 15 / Company 73 = 21 )
When I try creating a chart the "normal way" it adds up all the company names one after another and leaves it all in one block of incomprehensible nonsense.
Any help is greatly appreciated!
Thanks,
Adam
MAIN RIG = CPURyzen 5 3600 @4.2 on all cores Mobo: MSI GAMING PRO CARBON AC RAM:Corsair Vengeance LED 16GB 3400MHz DDR4 GPU:MSI GTX 1080 GAMING X OC Storage: Corsair MP510 NVMe M.2 480GB, 2x SSD HyperX Fury 512GB (games) PSU:EVGA Supernova 850w G+ Gold Display(s): , LG GL850 1440p 144Hz, HP Z24i (Color Accurate work) Cooling: Hyper 212 LED with Noctua NF-P12 Keyboard: Corsair K68  Mouse: Logitech G502 HERO Headset: AudioTechnica ATH M50x  Case Thermaltake Versa H27
Laptops =  HP Elitebook z17 G5 (i7 8850H, Quadro P5200, 64Gb DDR4)
Alienware 17 R3 ( i7 6700HQ, GTX 965m, 32Gb DDR4)
https://linustechtips.com/topic/958103-struggling-with-excel-2016-please-help-asap/
Pivot Table.
1) Select all your data
2) Go to insert bar
3) Insert 'Pivot Table'
4) Hit ok to select the defaults
5) Drag your company variable to the Rows box in the lower left hand corner
6) Drag your company variable to the Values box in the lower right hand corner
7) Then you can add any type of Pivot Chart to this and it will automatically build it.
Example.xlsx
Example 2.xlsx
Correcting myself, its actually COUNTIF function. =COUNTIF(<range>,company) gives number of matches for that company in specified range.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
