PC wont allow HDR & 144hz(Pics!) please help
imageproxy.php?img=&key=17c10421afdc6db8as you can see i did everything right but it 144hz, HDR is just not working...
i used displayport, GPU to monitor
i updated both windows 10 & Drivers
Windows 10 display setting wont show HDR option, it only shows night mode
but it still shows that i can only go up to 98hz on the PC display setting info & info on monitor i even OC it at 144hz still no help, no option for 120-144hz
what am i doing wrong? please help me out :(
https://linustechtips.com/topic/957611-pc-wont-allow-hdr-144hzpics-please-help/
What DisplayPort cable do you have? Is the cable physically capable of pushing that much bandwidth through?
Quote
  • Standard DisplayPort cables are certified to handle up to at least 21.6 Gbit/s (the full bandwidth of DisplayPort 1.2)
  • DP8K cables are certified to handle up to at least 32.4 Gbit/s (the full bandwidth of DisplayPort 1.3/1.4)
You need DisplayPort 1.4 capabilities here, because HDR and 144 Hz.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
6 minutes ago, bindydad123 said:
I think the 980ti only has displayport 1.2 which means 120Hz isn't possible at 4k
not true, my brother has a 980ti and it worked perfectly fine with his PC, and im using the same displayport that comes with the PG27UQ
the displayport im using came with the PG27UQ which supports 144hz, 4K, HDR. yes it is capable of pushing it
22 minutes ago, saif96 said:
PC HDR is basically all BS anyways still
You probably just need more bandwidth.
Or set it to 120hz
Or set it to 120hz
BS? what are you talking about? i own it and i tested far cry 5 HDR and it was amazing! it was colorful the blacks were more black and whites was more white, it was like a ENB mode, its not BS at all
and i told you it wont allow me to go more then 98hz something is wrong with the PC its not happening on my brothers PC
First issue is 980Ti and HDR: https://www.reddit.com/r/nvidia/comments/7zovep/4k60_hdr_actually_possible_with_a_gtx_980ti/
980 Ti only has DisplayPort 1.2 ports, no way you are going to fit 4K 144Hz through there. Especially with HDR.
And there's the bandwidth problem
Just wait for next gen Nvidia GPUs being announced on the 20th
i know it wont run well but im using the 980ti temporarily till the 1180 comes out i just wanna test a few games for it till it comes out and my brothers 980ti worked, why cant mine?
One of them might have more bandwidth or something.
Or Chroma Sampling was worse on one for some reason.
im not aiming at 144fps at 144hz, HDR, 4K i know its not possible, what im looking to is to game 4K, HDR at around 30fps but theirs no option to turn on HDR, how do i turn on HDR?
The older display port spec might not even support HDR.
Or try running the montior at 1080p
like i said before im using the PG27UQ displayport its by no means old.
and even if i tried running 1080p it would not solve anything because HDR menu is still not showing in the display setting
He is saying that your 980ti has DisplayPort 1.2 ports, the monitor needs DisplayPort 1.4 to run at 144hz, 4K, and HDR at the same time. DisplayPort 1.2 DOES NOT support HDR to begin with, so if you want to use HDR you need a newer GPU with DisplayPort 1.4 ports.
Watercooling Pro & Keyboard Enthusiast!
Only sort of.
https://www.reddit.com/r/Monitors/comments/8r4dg6/psa_4k_144_hz_monitors_use_chroma_subsampling_for/?utm_source=reddit-android
Quote
These 4K 144 Hz monitors use YCbCr 4:2:2 chroma subsampling to reach 4K 144 Hz. If you want RGB or YCbCr 4:4:4 color, the best you can do on these is 4K 120 Hz with 8 bpc color depth, or 4K 98 Hz with 10 bpc color depth (HDR).
then why is it when i set my monitor to 1080p i still have a limit of 98hz, my old asus monitor could go up to 144hz but not my new pg27uq and in my old pc (that had 980ti) did have the option for HDR but not the new one
I have no idea about the 98Hz. It may have something to do with the G-Sync HDR module and older displayport versions or your specific GPU. Did your old pc have a different model 980ti than your current one?
Because the 98 Hz refresh rate is imposed by the transmission interface (cable system), If you have GPU scaling turned on then the refresh rate limit will stay the same, because the transmitted resolution is 4K no matter what resolution you chose. You would need to switch to display scaling to enable higher refresh rates at lower resolutions. Previous G-Sync modules don't support display scaling, I'm not sure about the one used in that monitor though.
so what exactly should i do to get 144hz, 4k, hdr to work? any step by step guide?
You would need to enable YCbCr 4:2:2 chroma subsampling. This is done in the NVIDIA control panel.
damn i really wished that i tried that before sending my pc back to the store :(
ill send him this instruction just incase he he doesnt know how to fix it
5 hours ago, saif96 said:
i tried that and it does not work, any other way to do it?
No. Can you show a screenshot?
EDIT: Since you are using a GTX 980 Ti, which only has DisplayPort 1.2, you will not be able to reach 144 Hz at 4K.
