So lets get straight into the question,
will i5 8400 and GTX 1060 6GB be fine and also enough for gaming and multimedia productivity
Because beside gaming, i m also planning to learn about video editing skills. So I may do lots of training in video editing.
If not can you suggest me some more good CPU + GPU Combo ?
I have at least $900-$1300 budget for building the PC.
Looking forward for the responses. Thank you and have a good day^^
with this setup, you have a lot of room to expand, and you won't bottleneck at all. The 8400 can handle a lot of horsepower.
Primary PC:
wow, my predictions of people asking if an i5 8400/gtx 1060 setup would be a bottleneck mess are accurate
What games? Chances are high that it'll be fine.
Honestly at this point, you might as well just leave it as "pair a midrange CPU with a mid range GPU and you'll be mostly fine".
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 17.7) | iPhone XR (iOS 17.7) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
i5 8400 and gtx 1060 is a budget-friendly-gaming-high-at-1080p I think wkwk. Plus I can make my PC becomes RGBeautiful with the left amount of my budget.
Well for games, I think I ll play the e-sports kind of game. Such as dota2, csgo, gta V, PUBG, fortnite, and so on.
Hi @DrumXKPCGAMER,
If you are going to be doing video editing I highly suggest that you definitely go for the 6GB version of the 1060, the difference is going to be noticeable for rendering and realtime effects/transitions. If you are using CUDA applications all the extra VRAM that you can afford will come handy :)
Enjoy your new computer!
NeXTcube 12400 Z690M ITX 64GB SN770 6600XT Sugo16 12.5
NeXTserver 9400 H310N ITX 32GB SN350 5500XT Fara R1 12.5
NeXTstation 9900K Z390 ITX 32GB SN750 6800XT Enthoo 12.5
5 minutes ago, LOOK OVER HERE said:
Fortnight could run on a 1050. I saw a friend who used some sort of old crap AMD APU in a leafblower laptop that was able to get 20-30 FPS.
If you're going hi-res, I would definitely recommend the 1060 for GTAV.
i don't play fortnight so i insist on calling it fortnight.
hmm okay okay. thanks for the references mate.
1 minute ago, Hashiba said:
Hi @DrumXKPCGAMER,
hello too @Hashiba
alrighty matee. with all the answers here i finally become 100% sure to go with 8400 + 1060 combo (bcs for the past weeks i ve been indecisive, whethere to pair 8400+1060 which is fit my budget or wait up a bit more to pair 8400 with 1070) wkwk. Thanks a lot by the way!
