Hey all. So I was gifted an older system on the am3 socket
It has:
Cpu- 8370
GPU- gygabite r9 fury
Ram- 32gb ddr3 1600mhz
And I put this system all together and when I pressed the on button nothing. No lights, just dead. I try again again making sure all wires a properly inserted.
Knowing the system worked before.
I tested the new power supply I just bought with a paperclip test and nothing.
I was wondering if the powersupplys fan would even spin because the fan doesnt turn on without load. I need answers! Thanks- max
https://linustechtips.com/topic/956981-no-sign-of-power-rm750x/
8 minutes ago, Tomkezm69 said:
Is this my only option? I dont have access to any other hardware
You did use the cables that came with the PSU, right? Just making sure.
You could try running the PC with as few parts as possible. Just the motherboard, CPU, GPU and a single RAM stick, to try and rule out any other failures. But if the PC doesn't react at all when you try to turn it on, you could return the PSU.
https://linustechtips.com/topic/956981-no-sign-of-power-rm750x/#findComment-11617157
20 minutes ago, Tomkezm69 said:
Yea that's what I thought. So how will I know if the issue is the power supply. I've tried hooking in the GPU and harddrive. Nothing
That's not enough of a load.
What motherboard are you using?  Most have an LED to tell you its getting power from the +5VSB.
With just the paper clip, can you plug a Molex fan into one of the leads to see if the fan spins?  Otherwise you'll need a multi-meter.
And as seon123 points out:  You MUST use the Corsair cables.  If you're using other cables, you may be shorting out the PSU.
https://linustechtips.com/topic/956981-no-sign-of-power-rm750x/#findComment-11617194
