So I've been Researching vr recently and I was wondering do I need a better cpu than I currently have
i5 650 dual core 4 threads 3.2 gHz
im planning on getting a GTX 1070 this Christmas as the prices will go down but from what I've seen you don't need a crazy good cpu for vr just a good gpu
https://linustechtips.com/topic/956782-do-i-need-a-quad-core-cpu-for-vr/
You really need a quad core. HTC Vive minimum cpu requirements are a i5-4590.
The i5-650 is 8 years old and on the slower side of life now
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
With that thing you wont be doing any vr.
As the cpu calculates your location in vr in realtime, you need a quad core for a pleasant experience, or for experience at all.
You can always try, but 99% your experience wont be pleasant/ it straight wont work. First gen i7s should be quite cheap, and should do the job.
You need a good CPU for VR... i5 650 is nowhere NEAR good enough for it.
Minimum I would recommend is an i3 8100 or i5 6600.
Why do you need a good CPU? well, your CPU has to handle all of the typical non-graphical computation for the game, plus location of positional tracking of your head and hands, location in 3D actors (movable models), etc.
typically, a VR version of a game will be about 25% more CPU intensive then a standard 1440p version of the game.
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
This is quite nonsensical. The positional tracking happens in any game, it's just a different input method in VR.
The only thing that really makes VR more CPU-intensive is that you need a minimum of 90FPS all the time (or nearly all the time). Other than that VR games actually even tend to be less CPU-intensive than non-VR games.
But a Core i5-650 is still very marginal for VR. It can be used, especially if overclocked, but it's not going to be a flawless experience.
All games calculate your location in real time, VR is nothing special.
Minimum requirement for an Oculus Rift is a Core i3-6100 though, so a dual core (with HT) can do it... but only just, and preferably on a newer one than the Core i5-650.
It is one thing to calculate the location of a fictional character, and calculating the position of a headset and 2 controllers from the input information of a lots of sensors 100 times a second.
The dual core should do easier VR games, but heavier VR games with AI's i dont think so much, i would just get a first gen i5 or i7.
I'm going to have to disagree here. Yes it is a different input method, but that new input method also requires more movement permission and 2 extra points that move in 3d space, and will often be in view. It's a lot harder.
And yes, 90fps min is 1.5x the work (ish) for the CPU then typical 60fps for gaming.
Overall, the OP should really upgrade if he wants to play VR games smoothly.
Also, Oculus' recommendation for CPU is BS. They do a lot of "inbetweening" and scaling to allow lower end hardware to run VR, but the quality is just not great...
Stille (Desktop)
Evoo Gaming 15"
2 minutes ago, Rockyjr1st said:
Ok now that I know I need a better cpu would an and  ryzen 5 1400 work or a and ryzen 3 1200
I would recommend the R5 1400 if you can afford it. certain VR games (like regular games) are more hardware intensive then others.
Stille (Desktop)
Evoo Gaming 15"
Thanks everyone for helping me out I'll be sure to invest in a good cpu for vr
The extra computational workload is completely insignificant.
As for a first gen i5, that's what OP has...
2 extra points is nothing.
90FPS is 50% more than 60FPS, thanks, that's really informative. But 144FPS is even more...
Also, Oculus' recommendation for CPU is very reasonable. They don't do scaling, only Valve has tried to lean on that. Oculus does ASW if the system misses warp repeatedly, but that's a good thing. ASW is far better than ATW or simpler reprojection modes.
