Give me some criticism, rate my build
https://pcpartpicker.com/list/8wDRgw
I have an old ssd, thats why its not in the build
Ill be waiting for the release of the gtx 1180 since people say its going to be better. And because they say its going to be the same price as the 1080 ti, i just put a 1080 ti. Ill be getting the cheaper card,if the 1080 ti is cheaper ill be getting that. You get my point
Ram,well 8GBs is enough for now. Its one slot because i plan to buy the same stick of ram when prices flop.
Gimme some critiiiicssssssss. Im ready
23 minutes ago, YourNewPalAlex said:
when prices flop
that's a very long time you are going to wait my friend
Switch the 1600 with a 2600, if you know how to flash your bios stick with the mobo, else take a B450 Motherboard
The PSU is garbage.. Why do they offer bronze in the first place -_-
I would advise a EVGA SuperNOVA G2 series
The PSU is not crap. It is a Tier 3 PSU. Great budget choice.
hi.
With Ryzen, I recommend you get dual channel memory. This will boost the performance of the Ryzen 5 1600.
hi.
In my eyes everything under Tier 1 is a no go ._. but that's just me I guess
Adjusted a bit.
Larger PSU, adjusted GPU price for that of MSRP of 1180, and uped the CPU.
CPU: AMD - Ryzen 5 2600 3.4GHz 6-Core Processor  ($165.99 @ Amazon)
Motherboard: ASRock - AB350 Pro4 ATX AM4 Motherboard  ($59.89 @ OutletPC)
Memory: G.Skill - Aegis 8GB (1 x 8GB) DDR4-3000 Memory  ($80.98 @ Newegg)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($36.00)
Video Card: Gigabyte - GeForce GTX 1080 Ti 11GB Gaming OC 11G  Video Card  ($750.00)
Case: Thermaltake - Core G21 Tempered Glass Edition ATX Mid Tower Case  ($29.99 @ Newegg)
Power Supply: SeaSonic - EVO Edition 620W 80+ Bronze Certified Fully-Modular ATX Power Supply  ($39.99 @ Newegg)
Total: $1162.84
Generated by PCPartPicker 2018-08-06 08:17 EDT-0400
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
That's efficiency. Not an indication of how good or bad the PSU is. I'd much rather take a CX than an EVGA G1.
Not good for the price.
Not everyone has the budget for a Tier 1 PSU.
hi.
A 1600 and a 2600 are basically the same. Its cheaper and easier.
Yeah but again im waiting for prices to flop and then get dual channel 16GBs.
It most definetly has a superior cooler meaning you can get more clock speed out of it
38 minutes ago, SolarNova said:
Adjusted a bit.
Total: $1162.84
Not bad, you really need to explain me why the second gen tho :I
I agree
Actually the r5 1600 from amazon comes with a wraith spire which is also good for overclocking. And its 165$ the same price lol
If you can spare a $100 or $200 more dollars i'd go with the 2600x
Solarnova's 2600 build is good, you can go with that as well
I really cant spare a penny. If i could id get the r7 1700
