Hi, EVGA 750 Ti  is running very cool and normal but the fan speed is making noise when it goes over 50%... you can hear disturbing noise from case .
I wonder if that is normal and generally GPUs make noise at around  50-55% fan speed. I really do not remember how new GPUs fan acts at 50% and if it makes noise...
GPU Noise video please watch it , at first 40% > 0:15,   50% > 0:25 ,  at 60% very disturbing noise, and so on.
Laptop: Sony Vaio E17 i7-3632QM // HD 7650M
Monitor: Asus Designo MX239H // TX-58DXR800 4K
Storage: SanDisk Extreme PRO, WD Black 500GB
Sound: Asus Xonar U7 MKII // Logitech Z906 5.1 THX
Mobile: Google Pixel 7
https://linustechtips.com/topic/956621-gpu-fan-speed-make-disturbing-noise-at-50/
3 minutes ago, giusgius said:
I wonder if that is normal and generally GPUs make noise above 50% fan speed.
Yes, when fans run faster, they make more noise...
You should be able to check fan RPMs (not sure about PrecisionX, but Afterburner can). How high does that go at 50% fan speed?
Desktop benching:
Not really hearing anything out of the ordinary. It could be that the fan is causing some objects to resonate, and that's what you're hearing.
Also i'm pretty sure putting up video's of cocks is against ToS (jk)
Quote
Did you watch the video I uploaded? there you can hear it, at the beginning fan is at 40% and is quiet but at 50% it makes noise. around 0:20-0:25
Quote
I have inserted the video link in my main post, please watch it, the fan noise at different levels: 40,50,60,70,80,100%...
I wanted to said that generally fan makes noise at 50% speed not above it, 60% I think it do makes noise, but not sure how much.
That's probably just resonance frequency then. Mine does it at 31%.
Yes I did. I'm asking for fan RPM because I have an EVGA 750ti SC lying around with fans quiet up to 70%. I just want to check if your fan spins faster than mine
Desktop benching:
Used Precision XOC software, minimum fan speed was 40% and had no noise, but it starts noise at 50% speed and at 70% is really disturbing noise.
So if your 750 has no noise at 70% that means that this 750 I tested has fan problem and needs replacement. Not sure if oil helps and worth it...
