Help me choose a nic
Altruist
1 = asus model 2 = tp model?
7 members have voted
  1. 1. Which do you believe is better?
https://www.amazon.co.uk/ASUS-PCE-AC55BT-Dual-Band-Wireless-AC1200-Bluetooth/dp/B01EX7KP46/ref=sr_1_6?ie=UTF8&qid=1533246917&sr=8-6&keywords=asus+network+card   (.1.)
or
https://www.amazon.co.uk/TP-LINK-T6E-Archer-Wireless-Antennas/dp/B013HCNTZU/ref=sr_1_11?s=computers&ie=UTF8&qid=1533247073&sr=1-11&keywords=tp+link+archer  (.2.)
Please don't be bias, only state facts.
and yes Bluetooth is nice and so is an external antenna,
but so is a black PCB and an internal solution with no addition wires,
yet cheaper product is good too :D
My broadband tops out at 200mbs ( shared between devices in the house)
if  you want you can leave an explanation below
I will look through replies at 11am edinburgh time
I may be wrong.
or
I only voted for 2 because I have had previous experience with TP Link cards. And the experience was good. BUT the ASUS card looks like it uses a Laptop WiFi card, which means it could be upgradable in the future. I would say either would be a good choice. To me the deciding factor would be if you need blue tooth or not.
you didn't take the external antenna into consideration.
I may be wrong.
You didn't mention that cost is a big factor here as this is already twice your original budget.
So while you COULD buy an after-market external antenna for the second one, it pushes the price even higher then.
Like I said in the other thread, I think there are a lot more benefits to the first option especially as it uses a laptop card which are far more common and well tested.  If it ever breaks or you want to upgrade, you need only replace the mini card and they cost half the price of the whole unit.
Router:  Intel N100 (pfSense) WiFi: Zyxel NWA210AX (1.44Gbit peak at 160Mhz 2x2 MIMO, ~900Mbit at 80Mhz)
Switches: Netgear MS510TXUP, Netgear MS510TXPP, Netgear GS110EMX
ISPs: Zen Full Fibre 900 (~915Mbit down, 115Mbit up) + Three 5G (~900Mbit down, 115Mbit up)
Folding@home Recent WUs
Upgrading Laptop CNVIo WiFi cards to PCIe
I get a weekly allowance of £20, 2 weeks that makes £40 i'd something that lasts.
And please take a rest from helping me :D, i narrowed it down this far due to your intervention.
I may be wrong.
