Corsair 1000D Dual System Custom Loop!
hey im planning a new build and just looking for some help/opinions.
(i know it will be difficult, so please dont just tell me how hard it will be in the comments...)
just trying to get some feedback on what you guys think about the loop or what i should add or remove?
hardline?
CASE: Corsair 1000D (Slate)
FULL EK BUILD
(both gpu blocks are rgb + so are both pump combos + the main cpu block is also rgb (blue one) )
system 1 is blue
system 2 is red
Rough preview of what im thinking would appreciate all the feedback thanks guys!
(if yall wanna know the specs lmk ill drop em under here somewhere)
Do you have any plans on populating the top rack? It would look empty even with just fans. Maybe add more radiators.
Also, see Paul's video on his build in this case. Part 1 of 5:
Yeh the fans by them self would look weird cause there would just be empty space in between. But Im pretty sure I’ll just add a top radiator to the main loop.
