Posted August 2, 2018 I got my Z370 Micro rig up and running, very happy with the results thus far. I don't currently own any B-die - but I want to. So, I'm looking at the data sheets - and it turns out the memoy QVL on my Z370 Micro contains almost exclusively quad channel kits. Now, since the motherboard only has two DIMM-slots, that's... weird. So, I'm wondering if I bought dual channel versions of the same kits (for example F4-3200C14D-16GTZ instead of F4-3200C14Q2-64GTZ) will the motherboard recognize these as the same chips and apply the appropriate timings? If not... what were you thinking of, EVGA? ... Or is the QVL completely irrelevant? Gaming rig: R5 3600 // MSI B450i Gaming Plus // 16GB Gskill FlareX 3200CL14 // MSI GTX 1080ti Gaming X // Intel 660p 2TB // Corsair SF600 // Modded Fractal Node 202 Workstation: i7 8086K // AsRock Z390i Phantom Gaming // Asus Dual GTX 1070 // 16GB Gskill TridentZ 3200Mhz CL14 // Cooler Master V650 // a variety of noctua cooling // a total of 2TB of SSDs // Fractal Meshify C Audio setup: Focusrite Clarett 8Pre // Adam A7X // Sennheiser HD 650 // Sennheiser HD 25-II Tertiary rig: 8600K // EVGA Z370 Micro // MSI 480 Gaming X 8GB // 16GB corsair Vengeance 3000Mhz // 500GB 860 Evo // Corsair RM750x v2 // Fractal Meshify C // Audio Technica M50x Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 2, 2018 RAM kits themself aren't single, dual or quad channel. The motherboard slots and cpu memory controller determine that. And when it comes to Intel ram compatibility is generally pretty good, and especially for only 3200mhz, any kit should work fine. PC - CPU Ryzen 5 1600 - GPU Power Color Radeon 5700XT- Motherboard Gigabyte GA-AB350 Gaming - RAM 16GB Corsair Vengeance RGB - Storage 525GB Crucial MX300 SSD + 120GB Kingston SSD PSU Corsair CX750M - Cooling Stock - Case White NZXT S340 Peripherals - Mouse Logitech G502 Wireless - Keyboard Logitech G915 TKL - Headset Razer Kraken Pro V2's - Displays 2x Acer 24" GF246(1080p, 75hz, Freesync) Steering Wheel & Pedals Logitech G29 & Shifter Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 2, 2018 Author 6 hours ago, RKRiley said: RAM kits themself aren't single, dual or quad channel. The motherboard slots and cpu memory controller determine that. I know, but they are still marketed as such. I contacted EVGA, it turns out they actually don't do any manual optimizations for the kits in the QVL. They are merely the ones that have been tested to work. I guess that's ok considering the OC focus of their products, and that manual timings will be better than preset ones. Gaming rig: R5 3600 // MSI B450i Gaming Plus // 16GB Gskill FlareX 3200CL14 // MSI GTX 1080ti Gaming X // Intel 660p 2TB // Corsair SF600 // Modded Fractal Node 202 Workstation: i7 8086K // AsRock Z390i Phantom Gaming // Asus Dual GTX 1070 // 16GB Gskill TridentZ 3200Mhz CL14 // Cooler Master V650 // a variety of noctua cooling // a total of 2TB of SSDs // Fractal Meshify C Audio setup: Focusrite Clarett 8Pre // Adam A7X // Sennheiser HD 650 // Sennheiser HD 25-II Tertiary rig: 8600K // EVGA Z370 Micro // MSI 480 Gaming X 8GB // 16GB corsair Vengeance 3000Mhz // 500GB 860 Evo // Corsair RM750x v2 // Fractal Meshify C // Audio Technica M50x Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
