Cheapest Multi-Monitor adapter?
Routh
Hello people! I have a Surfacebook 1 which has a Mini DP port. I want to have a dual monitor setup but I really cannot afford a $200 surface dock. I already have a mini DP to VGA which I have been using with my current monitor. I was wondering if I can just buy one of these  https://www.amazon.com/Adapter-Output-Multiple-Monitors-Windows/dp/B00D4OUT7I/ref=sr_1_6?s=electronics&ie=UTF8&qid=1533149974&sr=1-6&keywords=usb+3+to+hdmi USB 3.0 to HDMI and plug that in as well. Will it work? Will I be able to extend all three screens(two monitors and one laptop)?
What resolutions are the displays?
You could use a USB to HDMI graphics adapter but I definitely wouldn't go with that one, Plugable makes some good ones:
https://www.amazon.com/Plugable-Graphics-Multiple-Monitors-2560x1440/dp/B01C6HBJOA/ref=sr_1_3?s=electronics&ie=UTF8&qid=1533161039&sr=1-3&keywords=plugable+usb+to+hdmi
I've experienced stutters and poor performance even with the nicest of USB to HDMI graphics adapters, depending on the resolutions you may be able to run both displays from the same mini DP.
Main PC: Corsair 900D | ProArt Z690-Creator | Intel 13900K | RTX 4090 | Trident Z5 (2x32GB) | 1TB 980 Pro, 2TB Sabrent Rocket 4+, 2TB 980 Pro, 1TB Sabrent Rocket | HX1200i
Capture PC: Meshify XL | Designare TRX40 | AMD 3960X | 2xRTX 4070 TI | Trident Z (4x16GB) | 2TB 970 Evo Plus, 1TB 970 Evo Plus | Dual HDMI 4K Plus LT, 2xElgato 4K 60 Pro, HX850
Media / Render PC: Corsair 900D (shared) | ASRock X399M | AMD 2970WX | RTX 4070 TI | Trident Z (2x16GB) | 2TB Samsung 970 Evo | 2xElgato HD60 Pro | HX750
Full Room Watercooling: EK X3 400 | EK-XTOP Revo Dual D5 | 4xHardware Labs 560GTX | 16xSilentWings 4 Pro  | EVGA 450 B3
Peripherals: Logitech G502 X |  Wooting 60HE | Xbox Elite Controller Series 2 | Logitech G502 Wireless | Logitech MX Keys Mechanical
Displays: Asus XG35VQ | 2xLG 24UD58-B | LG 65UH6030 | Asus VH242H | BenQ GW2480 | HP 22CWA | Kenowa CNC-1080P | Asus VC39H
Audio Interfaces : RME Fireface UFX+, Scarlett 18i20, RME HDSPe RayDAT, RME HDSPe MADI FX, RME ADI-648, RME ADI-192 DD
Audio Playback: 2xYamaha HS5 & Yamaha HS8s | Sennheiser HD820, Sennheiser IE 500 Pro, Ultimate Ears RR CIEMs
