Hello,
I got my hands on a Macbook Air 2012 13" and I want to get a USB to ethernet adapter for it.
I tried this one and it didn't work with latest OSX.
https://www.linksys.com/us/p/P-USB3GIG/
I recently found this one at around 20 dollars and it seems it has a driver for 10.13. Have you guys tried it?
https://www.tp-link.com/us/products/details/cat-5523_TL-UE300.html
Do you guys know any other USB to Ethernet (gigabit) adapter that works without problems and out of the box on OSX High Sierra (10.13) ?
Thanks
I believe the best solution here is a thunderbolt to Ethernet adapter. If you NEED a USB to Ethernet cable the AmazonBasics one might work.
https://www.amazon.com/AmazonBasics-1000-Gigabit-Ethernet-Adapter/dp/B00M77HMU0
"Kieran just stole my girl!" - No-one
Discord: Kdog#7258
I'd honestly just get the TB>GbE adapter from Apple. Trying to save $10 on an adapter isn't the right thing to do if you're looking for decent support.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
I want USB because I might use it for Windows machines too and I don't like adapters that have use only on one of my devices. Usb is more versatile.
Thanks for the Amazon one, gonna research it some more in those comments.
If you tried any other ethernet to usb on 10.13 let me know.
