System Update: Watercooling! "Project R"
S2000Gan
Hello again everyone.
I recently got some parts to build my first watercooling loop!
Unfortunately, my Lian Li Lancool K63 is not really designed to mount much other than 140mm fans...
So I picked up a new Fractal Design Define R6.
My plan is to keep my Black/Red build but now It'll be in a white case!
Why the switch to a white case? I'm going for a "Type R" styled theme. :D
Once I get the system built and running I plan on picking up a Red Honda badge and a Type R badge for fun and putting those in there somewhere. After seeing some pictures of systems in white cases I've decided I'm going to avoid putting a bunch of red LED stuff in the computer because I'm not a big fan of how all the white surfaces reflect the red light into kind of a pink-ish-ness. Instead I'll be sticking with the white LEDs in the reservoir and CPU waterblock and potentially adding a white LED strip if I think it needs more lighting.
I'll probably keep the green GEFORCE GTX on for fun, although we will see how the LEDs on the Ballistix Tactical Tracer RAM look and whether or not I end up having those LEDs on since they can only be Green or Red on the ones I have.
I'm still running my 2500K although I'm interested in seeing if the water cooling (especially on the VRM) helps my temps enough to lower the voltages I use for my current overclock. I'll probably end up taking this whole computer apart and replacing the current platform if the 9900K and 9700K really end up being 8 core CPUs (which kinda of makes the Gene-Z VRM waterblock seem like a waste, but hey I got it on clearance for really cheap. Also while I love the GTX 770 I have (Thanks EVGA for making a Titan cooler version at the community's request!), I am probably going to upgrade it when the 1180 finally releases (possibly a Hydro Copper version? Or if not at least a Hybrid?)
For now it's just soft tubing although I would like to do rigid tubing at some point. I've bent PETG before (Thanks to BS Mods for coming to LTX 2017 and 2018) so its really just a matter of building up enough funds to spend on all the stuff I need for that. Probably wont happen for a while. Priority is saving up money to upgrade the platform (CPU/Board/RAM) and graphics card.
Anyway, here are some pics of my system in my old case, and what it looks like at the moment!
16797555_10155009938127812_2576035681808466993_o.jpg?_nc_cat=0&oh=6bc1baff5b9e1536044f385138c44725&oe=5C0967E6
16903183_10155008729292812_8610245629182476208_o.jpg?_nc_cat=0&oh=de2b23a8c495afbc0e6571f13139f130&oe=5C02CB73
38269204_10156573411982812_6270953741684310016_o.jpg?_nc_cat=0&oh=881157ef6a7c9cc40a45c1615783fd0b&oe=5BD8DD9A
My System - Featuring Custom Laser Etching: (Out of Date - Need to update with current system pictures)
http://linustechtips.com/main/topic/11149-my-custom-rig-ft-custom-laser-etching/
