RX 580 8GB 1505Mhz and climbing
Go to solution Solved by Guest,
Try unigine superposition, it is much more taxing on the gpu than valley.
To get stresstesting for free on there choose "game", and then cinematic on the top left corner.
I've been steadily working up my overclock on my RX 580, but it's to the point where I'm hitting 1505mhz on the core with memory clocked at 2250Mhz and it still seems stable. I've left Unigine Valley Benchmark running for 2 hours now at high detail and 1920x1080 resolution with this overclock and it was still running fine when I came back just now to check. My max temps during the benchmark never exceeds 70* and my fan curve doesn't even set itself to 100% until 75*.
After reading other peoples overclocks on 580s I was expecting to max around 1480Mhz.
Is there any other ways I should use to verify that I am indeed still stable? My current method is to set my overclock on the card with MSI Afterburner and then run Unigine Valley for at least 30mins each time I adjust it. It just seems strange that it'd still be stable at 1505Mhz.
Heaven isn't the best. Gaming and actual use is the best. I've had overclocks run in Heaven for 5-6 hours, and a few firestrike runs and it crashes within 10 minutes in bf1
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
i think it was steve form GN that did a video about this recently, just because you can doesn't mean you should do it, you'll get errors. But if all seems ok go for it.
I'm downloading Unigine Superpostition now, so hopefully, that'll give me more accurate tell on if it's stable or not.
Can you possibly find me a link to the video? I was sitting here wondering to myself on whether I should push it as far as it can go comfortably, or if there was a point that the benefits per FPS are smaller than the upped voltage make it worth.
